Does it matter if my panhard bar relocation isn't perfectly vertical?
![](https://cimg9.ibsrv.net/gimg/ls1tech.com-vbulletin/1400x2000/img_20170920_133629082_9dbf8ff0c0826246454fa0775b39c191164a85a9.jpg)
So I recently installed a UMI panhard lowering bracket yesterday. I didn't really read ahead in the instructions to see why they want you to keep it vertical when you drill the holes (you insert washers in the gap between the driver's side holes to keep it vertical.
I got the panhard adjusted center but now I'm worried my geometry could be f'd up and want to know if I should get a weld on bracket instead to fix it. I'm lowered and have bump stops so I'm not sure if it will matter. Thank you.
