Burned brake line! Where to buy replacement?
Installed a turbo kit which is very tight in the engine bay, had to try and bend the hard brake line away from drivers side header that goes into abs block and wrapped it, apparently the heat was too much and burned through the hard line, Anybody kno w where I can get a replacement hard line with the flex part that goes into abs block?
something like this help?
http://www.ebay.com/itm/1998-02-Chev...53.m1438.l2649
Friend of mine bought them when he did his front and rear suspension...they were perfect fit, I helped him install. Planned on buying a set myself when I toss my tubular front end and SJM ABS delete kit together and on the car.
