Bolt on SFC question
Old Oct 6, 2017 | 08:59 PM
gocubsgo's Avatar
Default Bolt on SFC question
My new UMI sfc did not come with hardware, no big deal, mistakes happen. I don't really want to wait till Monday to place the order for the hardware. UMI customer support says that not all hardware can be purchased in stores because of some special brackets. I work in machining/fabrication and can make whatever brackets I need. Can anyone give insight or post pics of the brackets I need. UMI part number is: 2027. Thanks
Old Oct 6, 2017 | 11:57 PM
UMI Tech's Avatar
(2) # 1000000- M12x100mm Bolt
(2) # 1000001- M12 Nylon Lock Nut
(4) # 1000014- ½-13 Bolt
(4) # 1000015- ½ Flat Washer
(2) # 2004H- Bar Nut, Zinc Plated
The bar nut makes it easy to reach in the front and secure the two 1/2-13 x 1†bolts without a wrench up inside.
Did you purchase directly from us or from a dealer?
Thanks and sorry for the trouble.
— Ramey
Old Oct 7, 2017 | 06:04 AM
gocubsgo's Avatar
Thanks. That will get me what I need. Purchased from a dealer.
Old Oct 9, 2017 | 02:48 PM
StoneColdLT1's Avatar
UMI, I assume that list is the same for your 3-point SFC (part# 2004) since it looks as if the 3rd point mounts to the same point as the tunnel brace and uses the existing bolts, is that correct?
Also do you sell all of the SFC hardware? I'm going to need some and I'd rather give you guys my business rather than Fastenal.
