Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird How to Replace Brake Line<br>Step by step instructions for do-it-yourself repairs.
replacing ls1 brake hardlines
so my brake hardlines by the rear end are garbage. they are rusted and feel weak so i want to replace the whole 2 brake hardlines.
is there anywhere i can buy new hardlines?
if i have to cut the lines and make new lines any tips or suggestions?
never made and bend brakes lines so dont want to put any lines on my car that will leak or break
thanks
thanks
Kleeborp the Moderator™
You won't be finding replacement hard lines any time soon - when I checked in 2007 for hard lines for my 2002 Camaro, I quickly found out that GM does not offer pre-bent, pre-flared brake lines that are a drop-in replacement. I still had my old lines, so I sent them to Classic Tube, and they made exact duplicates of my factory lines in stainless steel, complete with flares, fittings, and stainless coil wire to protect them from road debris. It took a while, but the lines were exact duplicates since they use a CNC bender to make them, and I should be able to call them in the future should I ever need those exact same lines again without having to send them anything to duplicate.
If you don't want to go that route, I'd suggest learning how to make lines yourself. With a few tools (a good flaring tool that will do metric bubble flares and a tubing bender), it really isn't that hard to do...just a bit tedious.
That's really great info -- did you replace all the hard lines? I assume others could call and order them without much fuss since you already primed the pump.
I only replaced the two hard lines that run along the rear axle, and it was for a 4-channel rear axle (ABS + TCS). I'm not sure if the hard lines are different between 3 and 4-channel rears, so someone would have to verify.
As long as you had a 4-channel rear and wanted those same hard lines, they could make exactly what you needed based off of what I sent them.
Well, I replaced all my brake lines a few years ago! I went to a local place here that is a hose and brass business and they sold me a 20 foot section of brake line that is used by mechanic shops. The great thing about this material is the lines bend by hand and you just start at the fitting and bend the lines to match you existing line.
SJM sales a flaring tool that I bought and used which worked perfect.
The total cost for the line was $30.00 or $40.00 and the flaring tool was whatever SJM sales it for.
I hope this helps!
N2
I hope this helps!
N2
the hard lines over the axle are different with the 3 and 4 channels rears. i have had a bad experience with classictube so i will not use them again. there are a few other companies out there that will make you new lines. for a cheap, quick fix, i bought lines from napa that i could bend myself and have them on the car right now. i didn't make the bends look nice but they do work.
ABS only = 3 channel (one sensor placed on the pumpkin of the rear end plus one sensor at each front wheel)
The line size is roughly 3/16", but I have no idea what size the fittings are.
Here's the Classic Tube link for complete line kit, factory style:
http://www.classictube.com/index.php...&submit=Search
Also, these guys have rear hard lines pre-bent for 4th Gens:
http://www.Flynbye.com/catalog/c3_p1.html
Bumping an old thread, but can someone tell me the difference between LT1 hard brake lines and LS1 hard brake lines (if any)? I'm looking for a set for my '01 bird but it has a 3 channel 10 bolt out of an LT1 I believe so I want to make sure I'm ordering the right set. (most likely gonna order from the supplier above since I can't find a set anywhere else but they have listings for both).
So what is everyone doing that wants to replace their rusted hard lines and reroute the lines up front around the K-member? I have no problem ditching TCS and ABS. I'm thinking of getting the rear kit in the first link and then pre-bending some stainless steel the lines for the front, or would it be better to get the CA1069-SS kit to make the bend adjustments and some Strano 692290 brake lines?
TCS cars have two separate lines running front to rear, non TCS cars have a single line that's split at the rear end. If you want to ditch the double line and replace it with one it would be fine but remember you still have to deal with the abs block up front. You would likely need to delete that completely then you're free to so whatever the heck you want.
Good luck, just bend up your own lines. I highly doubt anyone makes a replacement line kit that will have the "extras" you want. Get a roll of nickle plated copper line(bends and flairs soooo much easier than SS put lasts and holds off corrosion like ss) and a good flair tool and take your time. I deleted my ABS and added roll control on my 95 pretty simply, and so did 01ssreda4 and he's got a good write up on here, his is also 4ch. The mastercool flair tool I have will do 45* and metric bubble flair as well.
None I know of. If you do something similar to what I did, the 3/16 nickle copper line will work going into the MC just gotta use the fitting off the stock line and make a metric bubble flare, then you can just do 45* double flair's on any adapters and unions etc. Also remember you need NPT to flair adapters for your line lock and proportioning valve if you're deleting the ABS block. I did npt flairs and tee's on everything but I also have my engine out so everything is accessible. 01ssreda4 did his on an LS1 car with the engine in and used some compression fittings of the correct size. here is his thread on it. https://ls1tech.com/forums/suspensio...bs-delete.html
