drive shaft twisting
Old Oct 15, 2017 | 06:23 PM
perfect.ta's Avatar
Default drive shaft twisting
This is regarding. A 99 trans am ram.air. it motor is making 520 tourqe. Stoke t 56. With a 12 bolt moser rear end and a BMR adustable tourq arm the car is in.original.hight. how ever it has performance. Shokes and spring . so far i dameged 6 drive shafts they ither break a yok. Or twist the drive shaft and snap it into.2 half . i tried adjusting. The tourq. Arm to play with the rear end angle.. I did what BMR recommended.-2 degrees for manual. Transmission. Still.split the shaft in.2 halfs. Now. Iv installed a pst. Heavy duty shaft but stil didn't. Beat on the car . is there anything els i would have to.look.for . thanks
Old Oct 15, 2017 | 06:39 PM
pdxmotorhead's Avatar
First thing I'd check (Cause its easy) is get under and check every mount and bushing on teh engine and suspension. I had a mount fail once that messed with the drive alignment under heavy power, it would kick to the side about an inch.. Throwing the U-joint angles out the window and breaking yokes..
Old Oct 16, 2017 | 07:47 PM
perfect.ta's Avatar
I checkd all mounts and iv emailed BMR they said most probably it's not the pinion angle. So far I have a BMR adustble tourq arm and stoke hight shoks and springs and rear BMR control arm and BMR subrame connectors . It's really strange why the shaft is failing m thinking next to put the car on Dyno and attached camera underneath it and see how the shaft reacts. Mean time if anyone can guide me on any thing El's I would check plz let me know . Thanks
