How I bleed abs brakes
Unscrew master cyl. Cap leave on top to keep fluid from spraying, if lines are empty, start by pumping pedal several times, don't worry about closeing screw yet , pump lightly not to the floor feather it keep try till you find the sweet spot,after it starts flowing start doing it so you don't get air in ,pumping to the floor, remember you don't have to pump hard at all,just the right way, after you get a good pedal,finish with a good gravity bleed
