K-member Hardware Size/Length
Does anyone know the lengths of the K-member bolts? I'm fairly certain they are M12x1.75, I need to pick up some hardware on the way home from work today, and left the bolts at home. Thanks!
Jon
Jon
M12x.175 - 40mm front 4 mounting locations
M12x1.75 - 20mm rear 2 mounting locations
hope this helps
hope this helps
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
^^^if youre referring to stock bolts you can't account that a portion of them does not actually contain threads. As these types of bolts are not readily available, he may be quoting threaded length only. Either would be correct as there is plenty of wiggle room in length for k member bolts. Since you are stabbing into a blind hole with a floating "nut plate" the stockers are turned down to lessen the chance of cross-threading and overall easier installation.
No I am not accounting for the "bull nose". I'll snap some pics with measurements next time I'm out tinkering on the car.
I looked at the hardware kit for our third gen k.
4th gen is 80/30
4th gen is 80/30
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
