PS cooler..? worth it?
ps i have all of the basic suspension mods
sways,shocks,springs,sfc,lca,panhard,ta
But, if the car is disabled because the engine has overheated or the PS has taken a dump, then I guess it COULD be considered an aid to handling.
For a car to "handle" it must be able to move under it's own power and the driver must be able to turn the steering wheel.
make sense?
But in this case, I don't believe keeping the PS fluid cooler is gonna make any diference in that mechanical part. It will work, then it will fail. Keeping teh fluid cooler will prolong the part's life.
Are you leaking/puking fluid?
RPM range while turning?
What size tires are you running?
Mileage on the car?
