Bump stop replacements - rubber
Bump stop replacement, can be found as low as $6/shipped ea.
OMIX-ADA Axle Snubbers 18271.07
https://www.google.com/search?q=1827107+snubber&rlz=1C1CHZL_enUS742US742& source=lnms&sa=X&ved=0ahUKEwiEkOCEnuXZAhVEq1kKHdnQ Cw8Q_AUIIigA&biw=1514&bih=734
Some place have the same bump stops for ~$30/pair +shipping
Rubber, not Urethane. Just bolt up, once lip is trimmed off body.
Comparison to the Energy Suspension Urethane options
The following users liked this post:
wannafbody (11-11-2020)
https://www.google.com/search?q=1827...w=1514&bih=734
Well done.
The angled/pointed end makes a difference though when compressed. Linear absorption or abrupt absorption with the wide and flat bump stop
I bought poly ones, and have them waiting for me when I get home, but I'd much rather have rubber. Ordering these, thanks!!!
*edit* It looks like it is totally rubber. Is there not a metal mounting plate it is molded to?
Thanks for posting this. I was on the Power Tour this year and I started getting a bad tire rub on the inner fender lip at every dip in the highway. Turns out the stock bump stops crumbled and fell apart.
It's a jeep part number but indeed fits all 93-02 fbodies
Bump stop replacement, can be found as low as $6/shipped ea. Some place have the same bump stops for ~$30/pair +shipping
Thanks! Can these be used with 295 size tires on C5 Z06 wheels with 1/8 inch spacers and not rub?
Yes. It doesn't change anything with your suspension, it just keeps your rear axle from crashing into the bottom of your car. If anything it will keep your tires from rubbing the inner fender lip by reducing suspension travel by about an inch. I never had a tire rub until recently when my bump stops disintegrated which allowed my suspension to travel too far.
