Rear suspension
I see that most prefer Strano/Koni, Strano/Bilstein or BMR/Bilstein. I don’t want to lower at all if possible. Maybe 3/4” max. I’m running 305/35ZR18 in rear and I had to ditch my bumpstops. I’m looking at QA1 double adjustable coilovers that include a plate to weld up in spring/shock tower for support. I know most coilover guys run Vikings but I’m leaning coilover for adjustable ride height more than anything. Looking for advise or feedback on street behavior with this setup.
Sway bar- same thing. Looking for street and handling not a fat drag bar. I know the Hotchkis is probably the best option but I don’t really want to spend $500+ on a sway bar. What I’m wondering is, would a 22mm solid be good or too stiff?
I went with the short tunnel mount (Spohn Pro unit) only because it seemed to be stronger. I’m planning on twin Precision’s and I figured, go big on TA.
How did you run a 315 and keep the bump stop? I didn’t see a way to keep em even with the 305. I rolled my fenders and it’s close with them cut off. Maybe it’s my wheels. I might try to fabricate some on there once I get the new rear axle and different wheels. I’ll check them coilovers out. Appreciate the feedback.
You want a shock that is at least gas charged at minimum. If you are worried about being lower you can keep your stock springs and use Koni Sports and have fantastic handling, ride quality and feel. Pair that with strano 35mm front, 22mm rear swaybars and the car will be very well balanced and flat in corners.
If you want coilovers you can run the UMI/Strano custom Afco's that are monotube and gas charged which will be ideal for handling and feel. There is also ridetech and Penske.
I have an 18” rear wheel, I believe they are repopped Corvette 18/17 wheels. I got them with the car. If I hadn’t already bought new tires I would go with something else because the brake upgrade won’t work with the 17’s. But the tires are very close to the inner tub and I’m not sure if they would have worked with the bumpstops. I would have tried to keep them but it wasn’t an option for me because the previous owner already cut them off completely. I’m a firm believer in a bumpstop, it’s there for a reason but it just surprised me that guys are fitting a 315 on with their stops. I don’t know why the guy removed them then. I’ll grab a pic of the inside when I get home from work. I really think these wheels have a lot to do with my clearance issue.
For a relatively low budget, I'd also say Koni SA's all around.
Springs, from memory I think on the upper perch it remains at stock ride height, or on the bottom perch it lowers it 3/4"? If you go with aftermarket, something like 500-650lb front rate and rear rate matched to your rear roll center height (probably 150-200 for stock, or up 200-300 if lowered significantly). Rear roll center gets adjusted by using aftermarket parts to lower the panhard bar or by using a watts link which has a similar mechanism.
Front bar solid 35mm if you like a quicker reaction on quick maneuvers such as a slalom and don't care about the extra 10lb of weight but a more jarring response to one-wheel bumps, or front hollow 35mm if you like the wheels a little more independently compliant over bumps. Rear bar I'd say around 22mm solid if stock rear roll center, or up to 24mm solid if rear roll center has been lowered a lot.
For a non-drag application the LCA's should be just slightly higher at the axle than at the chassis... 5-8* angled down seems to be a recommended value with the car at the expected ride height. If that's close to what you can achieve without the lowering LCA brackets, I'd leave them off. If you choose to use them, I'd definitely weld them on.
The above should give you a fairly neutral vehicle where you can perform a bit of throttle oversteer when necessary to help aim the car.
For the rear wheels, that's not much clearance. I'm currently running a +50 offset ZR1 replica with a 1/4" spacer, which puts my effective offset right around 43-44mm. My new unmounted wheels are ~44mm offset. For street tires, that ~44mm offset might be enough if you don't use a lot of lateral grip.
If you do end up rubbing, a combination of correct effective offset, big hammer, tubular LCA's (which you already have), ride height adjustment (which isn't easy on stock rear suspension), more spring rate (but too much is bad), fender rolling and more round (less square) edge of the tire (where the sidewall meets the contact patch) will work. You won't necessarily need all of them, but those are the common adjustments depending upon where it's rubbing.
Higher rear spring rate will reduce rear lift during braking and reduce squat during acceleration. The higher rate rear springs may be harsher over bumps, dips & rises, but it will have less float. I'd go with the 600 fronts and either 150 or 200 in the rear depending upon your preferences.
