do i need anything else? 2000 TA
Old Mar 16, 2018 | 03:44 PM
blue09rocket's Avatar
Default do i need anything else? 2000 TA
Getting ready to swap out my front and rear shocks/springs, I'm getting Koni STR.T, I do not believe the Konis come with any hardware, Id have to ask them before I order. I'm also getting new front upper strut mounts and strut bearing plate insulators. Just curious if I need anything else, don't want to get halfway thru the project and come to a stop. Thanks all.
Old Mar 16, 2018 | 03:53 PM
HCI2000SS's Avatar
I assume lowering springs of some sort? If so, doing the relocation brackets is a good idea
Old Mar 16, 2018 | 04:02 PM
no, stock height springs
Old Mar 16, 2018 | 04:11 PM
anyone have any part numbers for the cotter pins, I want to replace them while I'm in there, thx
Old Mar 16, 2018 | 07:35 PM
dojob's Avatar
Hardware for struts and shocks? All that would be in question is the lower front bolts. The upper fronts are in the engine bay, you can break those loose I'm sure no problem. Not even a part of strut. The rear shocks have hardware built into them
