Weld on rear sway brackets
I just ordered a backbraced Ford 9 inch and Umi weld on sway bar brackets. I need to give the company building my rear an angle to weld them on at. Could someone give me the angle in degrees relative to the pinion?
Stock sway bar and mounts will be used.
LS1Tech Premium Sponsor
Be careful with this. There is no good set location to put them. I would mock it all up with your specific sway bar first to make sure it clears the center section, then locate the brackets accordingly. Some bars do not have enough offset to clear larger aftermarket center sections. This requires you to rotate the bar backwards to run behind the center section some
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
