triple poly combo questions
Old Jun 28, 2018 | 12:06 PM
LoneSStar's Avatar
Default triple poly combo questions
wanting to swap out my torque arm bushing and trans mount , I upgraded the motor mounts to poly when I did my cam swap, wanted to know if it be a problem to run all three mounts poly? I searched but couldn't find a thread on a triple combo on poly motor mounts , poly trans mount, and poly torque arm bushing, car is a 02 m6 on bone stock suspension with factory bushings ... thanks guys
Old Jun 28, 2018 | 02:59 PM
blackandgold's Avatar
You shouldn't have any problems, as far as I know the only thing you don't want to do is run all 3 solid mounts.
Old Jun 28, 2018 | 03:21 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
^ this is correct. No problems using all Poly. Its when you start mixing in solid mounts that the issues begin.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Jun 29, 2018 | 10:06 AM
LoneSStar's Avatar
alright triple poly it is then , thanks guys
Old Jul 2, 2018 | 12:47 PM
stockA4's Avatar
I've had the best performance with the softer stock trans mount along with poly motor mounts and poly tourqe arm bushing. This setup will be a noticable improvement over stock and still works fine with stock or better yet with upgraded control arms and panhard rod bushings
I just got a lot of added vibration from the poly trans mount. I'm an A4 though so results will vary depending on the setup
Old Jul 2, 2018 | 05:39 PM
sjsingle1's Avatar
this is my setup also......i had poly trans mount but went back to stock rubber.......and if you are going to use stock rubber be sure to go gm/acdelco
Old Jul 10, 2018 | 05:50 AM
leadfoot4's Avatar
I had poly in the motor mounts, transmission mount and torque arm bushing in my former, street driven '96 Z/28, for a number of years, with no issues.
