Infernal rear end squeaking
Instead of dealing with bushings I just ordered bmr replacements arms with polyurethane bushings.
Finished install today, went great. I still have that infernal squeak.
I even get a less audible version when driving.
unless I totally missed something with the spring/shock install, what else could be the culprit? It's harder to isolate with the car in the air and wheel off.
Any chance the upper rubber piece that the spring sits in could be the culprit? Maybe just enough wear to be uneven...
I crawled under the car after thinking it was panhard bar bushings and went to confirm and both sides sound like upper part of the spring on both sides. Both springs are new, I did not replace the that upper rubber seat. I felt no vibrations on other bushings.
Yes,I guess the rear spring upper insulator could squeak. Any difference in the strength/loudness of the squeak with the hatch open/up ?
I once had a squeak that I isolated to the spare tire,clamp down fastener wasn't tight enough and the rubber of the spare was rubbing against something.
I replaced the springs/shocks because I was getting terrible rear end float from blown out shocks. I did the springs since I was already there.
I had tightened the nut at the top of the shock a smidge too much, which caused the bolt&bushing not to sit flush with the bracket on the bottom.
So when the body compressed the shock, it hit the bracket weird and squeaked. I loosened the nut up top a bit and all is well.
The plus side to all of this, my rear end got some much needed attention to bushings that were well worn.
