Strano/Koni assembly question
Old Jan 1, 2019 | 10:00 AM
99Silver6.0's Avatar
Default Strano/Koni assembly question
Happy new year!! Since I’m going to be graced with a 55 degree day this coming weekend I decided im going to install my pile of suspension parts that has been sitting in my garage for a few months. Can I assemble my springs and shocks just by using someone’s picture rather than having my car here to compare the old parts for correct alignment/orientation? My car isn’t close and I wanted to tackle getting these together so I’m ready to go. I did buy all the needed parts so I didn’t have to use any rusty parts from the originals.
Old Jan 1, 2019 | 06:09 PM
RevGTO's Avatar
Pontiacerator
Sure, but you'd better be sure you can rely on the pictures you have available. As you implied, the critical thing is to have the upper and lower shock mounts in the correct alignment as the old shock when you snug down the upper shock nut. Otherwise it's pretty much a no-brainer.
Old Jan 1, 2019 | 06:56 PM
Im gonna see if I can come across a good fully assembled picture that somebody has posted recently. I would think that should be sufficient given they put them together right! I’ll tale the stuff in to work and compress the springs and bolt them together.
Old Jan 2, 2019 | 11:04 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
