LCA position on relocation brackets
Old Mar 31, 2019 | 09:26 PM
BitPilot77's Avatar
Default LCA position on relocation brackets
Im installing some da LCA and have the umi relocation brackets , cars also at the same time getting lowered with a strano spring and koni sport upgrade .......im wondering what position would be best for the lca on the reclocation brackets?
Car wont ever be at the track just spirited street driving i only average 2000km/ year on car.
Old Mar 31, 2019 | 11:36 PM
qweedqwag's Avatar
Bottom.
Old Apr 1, 2019 | 07:46 AM
mikedamageinc's Avatar
Whatever makes the lca's closest to parallel to the ground. If you are in between, slightly down will give more launch grip, slightly up can give better roll steer. Thats very general and you may not even be able to tell a difference.
Old Apr 2, 2019 | 10:28 PM
Midnight02's Avatar
Mike's reply above was spot on. The general consensus around here is the bottom hole. For what it’s worth, I have a road course setup on a lowered car and the brackets on my Strange S60 rear have a 4th bolt hole at the very bottom and that’s where I’m running it.
