Line lock install, line question.
Old Apr 6, 2019 | 10:02 AM
Dano 00TA's Avatar
Default Line lock install, line question.
I'm in the process of installing a line lock now but as far as the brake lines go, what size are the fittings on the MC and ABS block? I've seen M12x1.0 and M10x1.0 and can I get lines with this size fitting already on it? I know I'll need adapters for the solenoid already but would like to avoid adapters on all ends if possible. Can a brake shop custom make the lengths I need? 8" and 22" Thanks
Old Apr 9, 2019 | 09:25 AM
biketopia's Avatar
Just take the lines off the master and ABS block and cut the fitting off, get some line and flair your fittings on it good to go.
Old Apr 9, 2019 | 08:28 PM
Dano 00TA's Avatar
I ended up finding instructions from a f-body hurst roll control kit for the size adapters I needed. I wanted to have everything ready and the lines bent before removing it to avoid as much spillage as possible. It's all hooked up and working. Thanks
Old Apr 10, 2019 | 09:00 AM
biketopia's Avatar
Good deal!! Mind posting up the the fitting sizes you used for future reference if someone is searching for this info and finds the thread?
Old Apr 10, 2019 | 10:57 AM
Dano 00TA's Avatar
Hopefully this can help someone out.
You need 1 of each of these 2.
3/8-24 Inverted to M10X1.0 bubble flare for the ABS block
3/8-24 Inverted to M10x1.5 bubble flare for the master cylinder
You need 2 of these.
3/16x1/8 MNPT You can get them either straight or a 90 degree elbow like I needed depending on where you mount the solenoid.
Also 2-3/16 brake lines in whatever length you need. I got PVF steel likes since they won't kink even w/o a bender.
Old Apr 10, 2019 | 12:27 PM
biketopia's Avatar
Awesome, thanks for that!! Another awesome product is NiCop brake lines, it forms super easy without tools, flairs really nice, and it wont rust out.
