A Arm route
Old May 8, 2019 | 09:22 AM
blackbirdls1's Avatar
Default A Arm route
I have most of my front suspension apart on my 01 bird. Took the lower a arm off as well. I’m going to attempt to press the lower ball joint out and change the bushings. They are destroyed. Rust doesn’t seem too bad. Anyone with experiences doing this? I will be renting the ball joint press from autozone. Trying to avoid going tubular due to the cost.
Old May 8, 2019 | 09:28 AM
98CayenneT/A's Avatar
You can buy a new a arm with bushings and ball joint assembled for $150
Old May 13, 2019 | 03:49 PM
xny1989's Avatar
In the past the replacement lower arms with the blue ball joint seal had problems with the longevity of the ball joint. I ended up buying used arms and replaced bushings and ball joints myself. I found that I needed several ball joint tool extensions to get everything out, and ended up having to get a 12 ton shop press to get everything back together. For me, it was a bear of a job, but I know I've got quality Moog ball joints and bushings in there. Haven't yet done the swap.
Old May 16, 2019 | 10:48 AM
landstuhltaylor's Avatar
It's easy to do with a press and the right size adapters
