Torque Arm Washers
I am installing an adjustable BMR Torque Arm. When I took my stock one, I noticed one of the bolts was inserted from the bottom where as the other one was inserted from the top. Does it matter how are they're put back it?
Another thing I noticed is that one of the washers was missing... So does anyone know which washer do I have to buy to fit on the stock bolts?
I am also a bit of an idiot, so I am wondering if anyone has a trick on how to get a good grip to be able to torque the bolts to 100 ft lbs... like I am working under the car and can't find a good spot to hold the upper wrench and get the 100 lbs ft with the torque wrench. :'(
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
I inserted the bolts from the top. Got a new washer and was able to torque them down. I struggled a bit, with what I think are the ebrake wires, but was able to find a spot to let the upper wrench sit and was able to use both hands to get the right torque.
Now I am having a few issues putting back together the Y and the I, but that was a bitch before, and probably will be since I angled the Y pipe down a bit.
