Koni Yellow's front spring seat bushing/rubber?
Maybe a stupid question, but I don't still have my stock shock/spring assemblies for the front. I'm doing Koni yellows and strano springs.
So far I've ordered the following:
Moog K6516/K6517 Upper Strut Mounts
Moog K6573 Upper bushing/insulator
The Koni yellow's already have the lower spring perch installed, which leads me to my question, does the spring simply rest on the metal perch, or is there a rubber insulator/bushing that is suppose to sit inside of the perch? I feel like there is but cannot find the part number.
Any help is appreciated. Thanks!
If I remember correctly I had to buy a moog lower spring seat which is part #K80927. It will come with the perch as well as the spring insulator you need which sits inside the perch. Simply remove the insulator from the moog perch and use it with the one's on the koni shock.
