1994 firebird brake lines help
I have a 94 firebird formula and recently it got a leak from the rear tee where it splits off to the rear tires on the drivers side. The pedal has to be to the floor to stop. The hard line from the ABS type thing next to the master cylinder that goes to the tee I pulled that line out today and can’t find what I need. I need help knowing the size of that line and the size of the fitting into the tee and ABS thing. And Glaring at the moment fro a while isn’t an option so I’m wondering what I can do to fix this? Please and thanks to the people who help in advance! It doesn’t have traction control either so it’s just 3 lines out of the ABS thing, read that the what I call the ABS thing is the brake pressure modulator
Last edited by Formulabird094; 10-26-2019 at 05:46 PM. Reason: Forgot important info
The parts layout catalog shows the line as 6mm (3/16"). No specs are given for the forward fitting. The line runs to a body mounted bracket that has one end of the flex line that runs to the rear end housing tee. From the tee a line runs to each rear brake. I needed to replace that hose assembly and had to go with an aftermarket stainless steel hose assembly. Most of my stuff had to be replaced due to corrosion and rust.
here's a link for the rear hose. at the bottom is a list of equivalents
https://www.carpartsdiscount.com/aut...ml?3593=252321
