steering shaft/ coupling shaft
I have a 1997 Camaro z28 6spd. My steering shaft/ coupling shaft rag joint and bottom u-joint have play. I require the entire assembly, does anyone have an idea of where to obtain one? Gm part no 26020775 is no longer available through the dealership.
You need to either take it out and replace the rubber disk with this http://www.unbalancedengineering.com/Camaro/Rag_Joint/ or replace it with an LS1 shaft.
