How to tell if I got 1LE stuff on my SS?
Is there a code on the door that tells meif Igot the 1LE stuff already? I was thinking the SS gets the upgrade from SLP when it gets the other stuff.
If it was built before 11/99, it will have much of the suspension (springs, front swap bar, rear LCA's, & PHB, but not the Koni's). That is what all '96-'99 SS came with. Teh 1LE option was not offered on any 2000 cars, and SS built 11/99 and later have the base Z28 suspenion with the 1LE front bar as the only suspension "mod" from SLP.
All '94 - '00 V8 F-bodies, including 1LE, got the same 19mm rear sway bar. Your car should have 1LE springs, LCA's (only difference is solid vs. windowed rubber bushings), PHB (higher durometer rubber buhsing), and front sway bar.
