Brake Master Cylinder bore size - 67 camaro
Old 03-01-2021 | 10:35 AM
youngrigo's Avatar
Default Brake Master Cylinder bore size - 67 camaro
I was planning on using the brake master and booster from my 2001 Camaro on my 67 Camaro build but the fittings on the brake master are on the wrong side.
So now i planning on using the brake booster but want to replace the master. I'm looking at a master with a 1in bore. Does anyone know if that will work or would i need a 1 1/8in bore?
Old 03-02-2021 | 02:49 PM
biketopia's Avatar
Need to know what brakes you are running, disc/drum or disc/disc and the number and size of the pistons need to be taken into account.
Old 03-04-2021 | 09:53 AM
youngrigo's Avatar
Disc / Disc and 98-02 Camaro front / rear calipers which are single piston
Old 03-04-2021 | 01:03 PM
biketopia's Avatar
The stock master is a 1" bore on the LS F bodys. So you're good to go.
Quick Reply: Brake Master Cylinder bore size - 67 camaro
