Pre made brake lines?
I know they make pre bent replacements for these, but I'm curious if they make line in specified length with the flares with the correct fittings for our cars. I know I could buy line and fittings and make it, but I was curious.
I'm getting ready to do an ABS delete and to clean things up a bit I was wanting some longer lines coming out of the master cylinder that I could just bend and skip having to flare the line.
for anyone else who finds this
MC1 3/16 line - m11 x 1.5 bubble flare
Mc2 1/4" line - mx12 x 1 bubble flare
You can get pre made brake lines with the fittings already on and then just bend them to fit what you’re trying to do. I did this when I did my abs delete. Just bought some straight line from a parts store and bent them with the tool to fit.
Perfect! So I just need to know line diameter and fitting sizes then
for now I really just want to my abs delete block so this would be a quick install if all I had to do was replace the master lines
