Upgraded suspension constantly bottoming out
In an effort to improve the handling and ride quality on my mostly stock 01 WS6, I recently put a some money into overhauling the suspension. My local LS1 shop did a nice job on the project and recommended Koni Street shocks (orange) all around, BMR upper and lower control arms all around, a BMR 1.25" lowering kit, and a BMR Panhard rod. Handling definitely seems improved, however it seems any moderate dip or bump in the road is now bottoming out the suspension which is going against my original desire to improve the ride quality since it is accompanies by a loud BANG and a kick in the ***, and I can't imagine this is great for the car either. Is this to be expected with the configuration above or are there adjustments or changes I could make to solve this?
Where is it bottoming out?
If it just hits the bump stops, shorter ones may be the fix you need
LS1Tech Premium Sponsor
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
You should share pics of your bump-stops at ride height and a shot of them once you get under there, as there are a lot of variables (such as, have they rotted off?). Look for witness marks on the axle where the bump-stops contact, but also along the panhard bar, and the torque arm--especially if that isn't stock. Sometimes the exhaust turns out to be the source of a loud bang, so look at that too.
See where that gets you. If you want to see where things bottom out, it is not hard to lift the car on jack stands, support the axle on the jack, disconnect the lower shock mounts, remove the springs, temporarily replace the shock mounts, and raise the axle up until it hits something. That will tell you exactly how much travel you have, and what it is hitting.
