Advice for stripped Bilstein shock stud
Hello everyone,
This is my first thread however I've been on the forums for some time. To get straight to the point I went to install LCA relocation brackets and BMR adjustable lower control arms on my '01 Z28. Mind you the previous owner had BMR lowering 1.5" springs and Bilstein HD shocks installed less than 2K miles ago. So I went to unthread the stud bolted to the axle on the right side and found it completely stripped. So much that it won't unthread itself. I contacted Bilstein and they say the stud assembly can't be replaced, they recommended a whole new shock.
I looked around the forums and found this: https://ls1tech.com/forums/suspension-brakes/1777520-broken-shock-bolt-can-anything-done.html
There a Dorman 31001 universal bolt and bushing assembly worked. I'm considering trying it out but I wanted second opinions. Buying a new shock seems unnecessary.
Would any of you trust that Dorman part as a replacement to the original stud assembly?
Thank you!
Thank you!
