BRAKE warning light
Old Apr 9, 2022 | 06:56 PM
YodiBrodi's Avatar
Default BRAKE warning light
The car is a 1996 Z28/SS got a brake warning light on the dash. Thank goodness I have a pair of factory manuals, went through the troubleshooting guide, the light goes off when the proportioning valve switch is unplugged. Correcting it seems simple enough, the spool valve is out of place for whatever reason, closing the switch illuminating the dash light. There is so little info available that is specific to our cars however and I’m just tryin to get a heads-up or a little guidance before I remove the thing and disassemble it to try and free that spool valve. Things like, is it able to be fully disassembled? Will I need to replace o-rings and seals? Are rebuild kits available and what is the part number? Any gotchas to be prepared for along the way? I’ll probably start with simply removing the switch and making sure it isn’t the problem. Thanks for any help fellas.
Old Apr 10, 2022 | 01:05 PM
bbond105's Avatar
Most of the time when the spool valve sets off the light it is because there is a brake fluid leak in the front or rear brake system. I would check for leaks before disassembling the proportioning valve.
Old Apr 23, 2022 | 06:48 AM
YodiBrodi's Avatar
Sorry so slow on the reply, I thought LS1Tech would give you a notice that someone had replied to a thread you’ve started. But to answer, no. There are no leaks and the fluid level isn’t low. Very first thing I checked. Not a noob.
Old Apr 23, 2022 | 08:56 AM
banshe5's Avatar
It could also be the parking brake handle switch. I’ve seen those get dirty and cause the light to stay on.
Old Apr 24, 2022 | 12:43 AM
YodiBrodi's Avatar
Nope. As the original post said, the light turns off when the switch on the prop valve is unplugged. It’s definitely the spool in the prop valve.
Old Apr 24, 2022 | 07:57 AM
banshe5's Avatar
I apologize, I missed that in the post.
