BMR or Stock rear springs
01 Camaro HCI car, curious as to how many of you use stock rear springs vs BMR lowering springs in the rear or if it matters. The stock springs are 20 years old, and I'm back there anyways, so what would you do? I'd like to lower it a little now that I have coilovers up front. The car hasn't been tracked yet but getting it ready and want to help the 60" ft as much as possible.
Strange single adjustable coilovers up front.
Strange single adjustable rear shocks in rear.
BMR 25mm rear sway bar with airbag in pass rear.
MWC tunnel mount
MWC rear lower control arms rod end
MWC pan hard bar rod end
UMI K Member and lower A arms rod end
Removed front sway bar
MWC tunnel mount
The following users liked this post:
Nathan C (04-26-2022)
