Hey guys, this has been driving me nuts the past few days and was wondering if anyone else has this issue.
For suspension mods I've got running right now:
koni str shocks with umi lowering springs
umi front and rear Sway bars
umi lcas with relocation kit
umi torque arm with umi tranny mount
umi tubular sfcs
umi adj panhard bar (with upper bar) with relocation
everything looks great except the fact that the passenger side rear end is almost an inch higher than the driver side...
I also notice when I jack the car up from the rear end the passenger side rises up almost 1/2 a ft before the driver side starts to lift up.. it's almost like something is binding that side..
I've tried messin around with the spring rotation, re unbolting all the suspension parts and torqued them down with the car sitting on the ground still the same deal
am I missing something here 🤔 Passenger side Driverside
If you just installed these springs, you should have indexed them, that is before removing your old spring, mark with chaulk the top end of the spring to the rubber seat. When installing the new springs, line up the top of the new spring to the chalk mark on the rubber seat. Doing this should ensure the vehicle staying at level height. JMHO (dont kill the messenger).
I think I may have figured it out, it looks like it's the UMI end links messing with the rear end alignment
I took out the endlink sitting on the passenger side (the side that's high) Passenger side end link removed
and now here's how both sides look like
this is while the end link on the diver side is still on. When I pull up and down on the passenger side swaybar end with the link removed that you can see how it twists everything especailly wheel height on the opposing side.
sooo question is how do I fix this... lol I guess I need adjustable end links?
I've been messing around with the suspension for hours for the past few days, was able to also get my rear end nice and squared up too as driver side wheel was 1/2" out vs the passenger side (lca adjustment) and panhard adjustments
SO..just for ***** I also undid the front sway bar and I believe this the issue, I left the rear alone as I busted out the measuring tape and everything seemed fine.. the front driver side endlink was pulling the car down by 1/2" causing the rear passenger right side to raise up. I know this because I was fiddling around with the suspension and at one point the driver side rear was now almost an 1in higher, it's like the lean swapped sides when I was messing around.
Here's how the car looks like when I undid the front driver side swaybar endlink after driving it around
Passenger side (same as driverside now just a weird angle) Now the car sits level Diverside Obligatory engine bay pic 👀 got some tidying up to do
so it's either the swaybar is off, something kmember related, front lcas.. or front strut related.. 🤔
I ended up cutting 1/2" off of the endlink sleeve on the passenger side endlink to raise the bar on the driver side to prevent any binding/preload while tightening up the driver side endlink and that seemed to fix the problem, this needs to be done with the front suspension loaded. Car is now perfectly level.
Took the car for a spin and wowww, the cornering and response is now absolutely night and day and here i thought it was already good having the UMI gear installed and before fixing the leaning issue
Adjustable endlinks here would probably work really good here.
