Alignment
Old Mar 17, 2023 | 09:31 AM
blackbirdls1's Avatar
Default Alignment
Who you guys use for alignments? Your local big chain tire shop? Specialty shop?
Old Mar 17, 2023 | 10:24 AM
lees02WS6's Avatar
Depends on what is done to your car, and what you intend to do with it. For a stock car, used on the street, the average alignment shop can handle that. Adjustable parts and/or using it for autocross or road racing and you'll want to find a performance shop.
Old Mar 17, 2023 | 10:27 AM
Street use. The only adjustable part I have is the panhard bar and the front lower control arms.
Old Mar 17, 2023 | 10:41 AM
lees02WS6's Avatar
So, track straight down the highway, and minimize tire wear? I assume front lower arms still use the stock eccentric bolts on the k-member for camber and caster. If that's the case any alignment shop should be able to handle it.
Old Mar 17, 2023 | 10:43 AM
Pretty much, it's not a daily but going in a straight line and even wear. Yeah stock bolts on k member.
Old Mar 17, 2023 | 10:48 AM
Actually need to check but i think they are the bolts that came with the a arm.
