Ok I got a 9in rear that I will be installing in my car when I get back from the desert. Question is what kind of sway bar do I need? I know im going to need one. the rear is made by Moser what kind of sway bar do I need?
I use a 21 mm 1LE rear bar with my 9 inch, but you can use any swaybar you want; you will just need to grind one of the torque arm mounts to get clearance. You will also need bigger muffler clamps to mount the bar; I think three inch.
