Recently i spun out in rain and ran onto the curb resulting in the passenger toe being in and driver side camber is too far positive and angled out at the top side, i was able to adust tie rods to fix the toe but i need help with how to adjust the lca or uca to fix the camber from as much i can see passenger side is straight has positive camber (driver side)
Adjust the lower cam bolts on the control arm. Loosen the nut. Use cam bolt to adjust camber with a wrench. As the bolt moves one way or the other the wheel will move in or out.
