Trailing Arm Angle vs Handling?
Thanks,
John
When I lowered the rear arms more I gained a lot more traction.
Thanks,
John
I appreciate all the great responses.
John
"Yes, moving the lower trailing arm to the next lower position should help with your wheel hop issue and improve traction. The overall effect on handling will be very minimal on a street car and typically not noticeable. "
So now I'll try relocating the trailing arm and see what happens. On the other hand, I'll be out of town for a month. I'll continue this post in July.
Thanks to all for your help,
John
"You'll want to start with them horizontal. Depending on car set up, you may want the axle mount to be a little lower than the body mount end. That will help plant the tires on acceleration. The LCAs on our 3rd Gen are about 1/2" lower on the axle mount end, and I like the way the car hooks on throttle application. With the axle end higher than the body mount end, you will reduce bite on acceleration, and can induce roll-understeer."
"As for hole patterns, use the closest ones that will get your LCAs level. The longer I play with geometry, I don't necessarily buy into roll oversteer being as big of a deal as it's made out to be. I really like the antisquat you pick up getting them closer to level."
"You should add the LCA brackets. The reason for this is that you want to keep the LCA's parallel to the ground for rear steer. The LCA brackets will allow you to lower the rear of the car and still maintain the LCA geometry. Without the LCA brackets you just can't lower the rear of the car as much as you'd like."
