Suspension Upgrade?
Old Aug 19, 2024 | 02:13 PM
KobeGigi's Avatar
Default Suspension Upgrade?
I have a 01 TA. Dyno'd at 475. Car is a wknd cruiser, no track or racing etc. I want it to handle better, what suspension upgrades would you recommend and what brand? I am new to the mechanic/swapping parts world but i do it myself by learning from you guys or videos. Any input is well appreciated.
Old Aug 19, 2024 | 02:38 PM
ss1129's Avatar
https://ls1tech.com/forums/suspensio...-tech-faq.html
Old Aug 19, 2024 | 03:22 PM
jmilz28's Avatar
Strano sway bars and shocks. Bilsteins or Koni yellows depending on your budget. Best suspension mods for these cars.
Old Aug 19, 2024 | 07:15 PM
jond99's Avatar
Weld-in subframe connectors should be on the list. Huge improvement.
Old Aug 22, 2024 | 12:23 PM
Sam Strano's Avatar
LS1TECH Sponsor
Nailed it if you don't want to lower the car (and you don't have to lower it if you don't want to). There are some gains to be had there, but physics applies and lowering the car means stiffening the car and like most things there is no free ride. There are tradeoffs, just a matter of what result you want.
Shocks have always mattered first. I deal in most all of them. Koni Sport being best for bolt on shocks, then Bilstein, then Koni STR.T, then most of the rest. The main issue from GM with these cars was **** poor shock control which manifests in floating and bobbing and as time goes on more and more impact harshness. Sway Bars are nice in that when PROPERLY SIZED they don't mess with any other driving dynamics but offer better performance in cornering and on the highway in high cross winds, etc. But people do screw that up because they think a few mm of size doesn't matter, when it matters a massive amount. Read that this way: Not all sway bars work the same way. Some are too stiff, some are too soft, and some are bad combo's of both. Springs the last of the big 3, and I don't think they are for everyone, despite making my own well proven set for a long, long time now (and they are in stock I'm not saying this because I can't supply mine, or even others). They just need to be thought through, how you use the car, where you drive it, what you want for looks, etc.
As far as SFC's and STB's and all that, those are not suspension parts, they are chassis parts, and while they have their place and you can see some tangible change mostly with some SFC's on some cars in some uses, they are not an automatic must have, certainly not before shocks at minimum.
__________________
Old Aug 27, 2024 | 07:46 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Another vote for sub frame connectors, stay away from the vendors, and order through the manufacturers (i.e. BMR, Bilstein, Koni etc.), you will get a better price without the BS. JMHO
Old Aug 27, 2024 | 08:02 AM
Sam Strano's Avatar
LS1TECH Sponsor
That's hysterical. That's where you get the BS. Because they are only gonna sell you what they have. Also I'm never more than they are, sometimes less.
__________________
Old Aug 27, 2024 | 06:34 PM
lees02WS6's Avatar
475 is stout. What is done to the car?
Old Aug 29, 2024 | 09:26 AM
hokeplaya05's Avatar
subframe connectors are a waste of money on a dedicated streetcar. spend that money on a good shock/spring combo (strano springs with Bilstein or koni shocks are hard to beat), sway bars and replacing any worn our bushings in you suspension and a set of good tires.
Old Aug 29, 2024 | 09:57 AM
jmilz28's Avatar
Totally disagree. They are a noticeable difference up front, over time, and for safety. They really let the springs, sways, and shocks do their job better. I prefer my car's chassis be a foundation for suspension more than an active part of it. They also prevent shifting panel gaps, door sag, and reduce creaks a bit. Did I mention safety?
Old Aug 29, 2024 | 10:23 AM
Kjduvall's Avatar
i like subframe connectors cause it gives a really good lift point. also the brake/firewall reinforcement that sam makes is another thing id throw on that list, makes a big diffrence in pedal feel.
Old Aug 29, 2024 | 11:13 AM
KobeGigi's Avatar
Having a hard time finding the Strano springs i would need. Going to buy Bilstein, do those Strano springs lower the car or are they some that ride just like the stock ones?
Old Aug 29, 2024 | 01:29 PM
Kjduvall's Avatar
you could just call him.... his number is in post 5 and 7.... he'll set you up.
Old Aug 29, 2024 | 02:38 PM
99Silver6.0's Avatar
Strano's coils only drop the car 1.25". I like how my car rides with them. Much more controlled without being too harsh.
https://www.stranoparts.com/partdeta...=113&ModelID=7
Old Aug 29, 2024 | 06:00 PM
lees02WS6's Avatar
In this thread Bilstein Shocks @KobeGigi said he was not interested in lowering. This is a weekend cruiser, so skip most of the aftermarket parts and
  • Go with bilsteins shocks.
  • Make sure you're using rubber bushings in all bushing locations, and be sure your rubber bushings are in good shape.
  • Remove the aluminum spacers from the bump stops in the rear, if you have them.
  • Make sure your rear bump stops are in good shape
  • Check your tire pressure, keep it at not more than 30psi.
  • Go with the most comfortable and quietest tire you can.
Old Aug 29, 2024 | 06:22 PM
Onbusy's Avatar
Your best bet is to call up and talk to Sam at Strano Performance, tell him what you want to do with the car and what you want from your car, and follow his advice.
I went with the Ridetech Level 2 kit, front a rear adjustable coilovers.
