Front camber after lowering
hey guys, i put eibach sportlines on a while ago and my front tires are wearing on the inside due to the slight camber on the front. i dont see any fix for the problem other than using springs that are not as low. anyone know of a fix?
thanks....
thanks....
im not a suspension guy but i dont think that a simple alignment fixes the problem. toe-in&out can be adjusted....but can you adjust the whole geometry of the suspension with an alignment?
Sounds like you've got too much negative camber (tops of tires leaning in), get like 1/2 a degree of negative camber in front. Racers do more, but if you go positive (like stock) you'll wear the outsides of your tires.
