Brakes boiling
They have been overheating to point of vapor lock at times. I have flushed the lines with valvoline synpower fluid which from what I hear is not the best but is up there. My pads are oe replacement, ceramix brand I beleive, I am getting some hawk's soon, but pads alone shouldn't be causing this much heat should they?
Front rotor might be a little bit warped, but nothing bad, and I have had worse without issue.
I am on race tires, so braking is much more aggressive before lockup.
ABS is not kicking in, I have gotten pretty good at braking to the limit without abs hitting
When I flushed the fluid, I filled the resevoir to the fill line, even through pads a rotors are used, could it just be too much fluid?
Rotors are brembo oe replacements.
My thoughts.
My solution would be to use a more aggressive brake pad. That will require less pedal effort and less assist for the whole run and will work better without assist at the end.
Just my thoughts.
Just an FYI, and not that anyone here would do this, do not buy Ceramix brand pads. The pad material was separating from the back plate on one of my old front pads.
Thanks for your help guys.
I doubt they are the best pads for our cars, but they are certainly better than stock or cheap oe replacements.
