Lowering, what exactly changes??
Is the torque arm put in a bind since your pinion angle changes?
Alignment will change. Not a lot, but some. When I lowered my Camaro (1.5") and went to the alignment shop, it was still within factory specs (Surprised me). I had the alignment "tweaked" for better handling while I was there though. So, you can get away with small ride height changes without killing the tires (more than likley, your results may vary). However, I'd still suggest using regular lowering springs to drop the car (my preferred method).
Pinion angle is usually fine for around 1.5-2" of lowering (give or take). I know of one car that was too low and had a very bad driveline vibration. This was a race car and was just too low. It was raised slightly, problem solved. So, you can go too far.
The front of a 4th gen F-body does not need camber plates (the suspension is designed in such a way that we can't use them), a 3rd gen can use them and can benefit from the additional camber (for handling, if you just want "low", then you can probably skip them).
Adjustable PHB seems to be required by some cars, and not others. So, it can't hurt to have the adjustment if needed, but it may not be required. You can always lower it and then order one if needed.
Relocation brackets. I don't use them, but they will allow you to reset the control arms to be parallel with the ground. You can always add them later as well.
Hope that helped.
Hope that helped.
http://www.streetnstrip.org/forums/s...=&threadid=959
Q: Is the torque arm put in a bind?thus stressing the mount points and the trans mount? A4 trans
Q: is a bump steer kit needed with a 1.5-2" drop? Just eyeballing the tie rods they are already pretty parallel to the ground.
Ok, it is nice to speak with someone who knows what they are talking about vs those that have just done it. Again, i am going to think about this and will let you know if I have any more questions. Thank you for the help.
These cars really do not need bump steer kits. You may be able to make things ever sl slightly better, but you need the bump steer measuring tools and time/effort. I've not seen a need, or found anyone who felt that the kit was required. Most of the F-bodies that are being raced (road raced) are not running a bump steer kit, so I'd pass on that one as well.
Can any and all binding be avoided? Like with an Adjustable torque arm, and adjustable lower control arms?
By the way I just visited your site, very nice. I wish I had seen that before posting here. Thanks.
To avoid binding, you need something that flexes. Rubber bushings flex (which is why the factory uses them), or Heim joints. Poly is what causes the rear suspension to bind. So, as long as one end is rubber (technically, still binds slightly, but not nearly as bad as poly) or a heim joint, you will be relatively "bind free". If both ends are heim joints, you should have no binding issues.
Did that help?
I'm glad you checked out the site. I need to do some more work on it soon, but it's always a work in progress. I hope you found some useful info on there.
Kevin
Did that help?
Kevin
