Spohn adjutable TA
Thanks ACE
I haven't really noticed any vibration over the Random Tech Arm I was using previously. But due to the design of the 'swiveling' front mount you will hear/feel a slight clunking noise when the car shifts due to the front mount moving thru it's arc.
Oh & BTW, you can only install the rear DS loop with the suspension loaded (such as on an alignment rack) if you try to install while the car is on the rack with the suspension hanging - it will not go on.
-Jay-
I even spoke with Steve on the phone - he didn't mention anything about needing longer bolts - if he thought I needed them, and actually sold them, why wouldn't he have reccommended them? I sure would have had no problem with spending $17 on some bolts after spending $450+ on the arm.
My car slightly vibrates above 75 mph, I haven't looked into too much yet. But I currently have a 0* pinion angle so I doubt that's the problem. It might be the tires or DS which I plan on replacing in the spring.
