do i have 1LE susp and need help w/swaybar install......
ok, i have an 01 SS....how do i know if i have the 1LE package???2nd, does the install from Installuniversity for the front and rear swaybar work if u were 2 use BMR products???tia
Check for the 1LE option code on your option list, or measure the front bar with a digital caliper. If the front bar is 32 mm, you don't have the 1LE package. If you are replacing the stock SS swaybars with BMR swaybars, you are making a mistake IMHO. The BMR front swaybar is the same size as the stock SS bar, it's just heavier because it's a solid bar. The fact that it's solid will not make it significantly stiffer.
