Random Tech Torque Arm
Old Nov 30, 2004 | 06:51 PM
MachoCamacho's Avatar
Default Random Tech Torque Arm
I have heard this is the best torque arm to use for TSP true duals, I was wondering how do they perform and what material are they made from? chrome moly or steel? are they as strong or stronger than BMR adjustable chrome moly torque arm?
Old Nov 30, 2004 | 07:09 PM
1BadMoFo's Avatar
I'd be interested in this also, I didn't realize there were any issues with any of the trans mounted TA's out there...I'm about to buy a BMR adjustable...
Old Nov 30, 2004 | 07:20 PM
WILWAXU's Avatar
I run one with a Yank tranny mount. Works for me.. but then of course I went 10.9's on the stocker
Old Nov 30, 2004 | 08:18 PM
shep28's Avatar
Funny you ask. I am also looking at this TA to give me more clearance with my TSP duals. Thunder Racing sells these. I wonder how much xtra clearance I will gain. My clearance issue is the proximity of the x pipe top to the duals.
Old Dec 1, 2004 | 12:06 AM
anybody have an answer to this question?
Old Dec 1, 2004 | 08:31 PM
1BadMoFo's Avatar
so do you already have an aftermarket tranny mounted torq arm, and you're hoping this one will give you more clearance?
Old Dec 1, 2004 | 09:44 PM
shep28's Avatar
I have a stock and I need more clearance for my tsp duals. My x pipe contacts the stock TA
Old Dec 2, 2004 | 06:05 AM
1BadMoFo's Avatar
no kidding?? my tsp duals easily clears my stock TA...have you tried re-adjusting it?
Old Dec 2, 2004 | 07:26 PM
shep28's Avatar
My car is lowered. I have the system tucked up real well. Good clearance under the car. The problem area is right above the x pipe on the drivers side.
Old Dec 5, 2004 | 02:03 PM
1BadMoFo's Avatar
to the top with this one...is the performance/strength equal to BMR's?
Old Dec 5, 2004 | 10:54 PM
sikws6's Avatar
they are both probably going to give you the same performance in the non-adj. forms but if you go adj. you can better tune your pinion angle for best results.Personal opinion I like the BMR torque arm better, looks like a stronger built piece, especially in chome moly!
Old Dec 7, 2004 | 07:15 PM
1BadMoFo's Avatar
my car is lowered so I'm definately going adjustable.
