Steering gear
Old Dec 1, 2004 | 02:15 AM
BadAndy's Avatar
Default Steering gear
Is there any way to change the steering gear ratio? The wheel turn doesn't feel responsive enough to me when I'm drifting around. Basicaly, I feel like it takes too much steering wheel input(wheel turns) to get wheels to turn the amount I want. Does anyone make a different worm gear assembly?
Old Dec 2, 2004 | 10:54 PM
Midnight F-117A's Avatar
A whole rack is gonna have to be swapped out for the ratio change.
Old Dec 4, 2004 | 03:00 PM
BadAndy's Avatar
Well that blows. What are my options?
Old Dec 4, 2004 | 03:36 PM
Manual steering rack or aftermarket one (don't know of any)
The V6's have a different steering ratio but it takes more turns of the wheel compared to the V8 ratio.
Old Dec 5, 2004 | 02:42 AM
badjuju342's Avatar
Deranged Rat Fink
A V6 rack will not fit an LS1 car. Someone I know did the engine swap in a '98 Camaro . The bottom is a LS1 rack and top a V6 , the angle where the steering column connects is off just far enough not to work.
Old Dec 5, 2004 | 03:34 AM
BadAndy's Avatar
No, dammit . I want less turns.
Old Dec 5, 2004 | 03:35 AM
BadAndy's Avatar
Sonofabitch. This is just like when I wanted to get different 1-4 gears swapped out.
Old Dec 5, 2004 | 04:16 AM
badjuju342's Avatar
Deranged Rat Fink
The weird thing here is the part#s for the V6 rack and the LT1 rack are the same .The LS1 is different ,go figure. I didn't even consider doing a rack conversion on my RS , I'm using an IROC-Z quick ratio steering box and stock front end components. I had the option of using a rack when I bought a tubular K-member but chose not to.
Old Dec 5, 2004 | 05:12 AM
BadAndy's Avatar
Could I use the IROC steering box and leave the rest the same?
