Wheel Hop, have done every suggestion ALL FAILED
Parts:
Moser 12 Bolt
Bilstein shocks
stock springs
Car is not lowered
Control arm relocation brackets (have tried multiple settings)
I have been through 3 different LCA's (Currently running adjustable Badz's)
BMR adjustable Panhard bar (I have tried others)
BMR torque arm (modified by TTP to fit Moser correctly)
Poly tranny mount
Sub frame connectors (dont know if they help or not)
Nitto 555R 16's
The only thing I can think of is the Nittos. I am going to try regular tires and see if I still get it. Has anybody else had this problem with Nittos? I get massive wheelhop even when the tires just spin a little. Sucks not being able to slide the car or do a decent burnout.
Moser 12 Bolt
Bilstein shocks
stock springs
Car is not lowered
Poly tranny mount
Nitto 555R 16's
Originally Posted by Bad Blu Formula
Check your pinion angle on the torque arm. Also, don't run a million PSI in your Nittos, that might help.
Which relocation brackets do you use? Are you using water for your burnout?
Mike
Originally Posted by V6 Bird
Does this happen on the street or track? I know Ive had hop on the street but no wheel hop on the track.
Mike
Mike
