Rear Air Bag.
Do I need to install the protector for the lower spring seat to keep the air bag from tearing? Also can I squeez the protector through the "expanded" spring like I plan on doing with the air bag. Should I let the bag rest at the bottom, middle, or top of the spring. I`m sure the guys that deflate them for the street have them settle twards the bottom of the srping. Just woundering if any of you guys would know. Thanks for any help fellas.
Al
Al
Yes, use the protector. The air stem will keep it centered. You'll have no problem slipping the protector into lower perch. Airlift bag, correct? Take the valve stem out, compress air from bag, and slip it thru open coil w/car rear jacked up and suspension "hanging". If deflated, the bag just finds it's own resting place within the coil.... WJ
Thanks fellas. I`m going to put it in this weekend. One more thing though. Dose the protector just lay in there or do I need secure it some how.
Thanks Al
Thanks Al
Thanks Al
Thanks Al
LS1Tech Co-Founder
You don't have to squeeze the airbag into the spring when installing it. Simply unbolt the rear shock absorber and jack up the car and the rear leaf spring will lift right out of the car. Then just slip the rubber isolator and bag into the coil. Takes maybe 10 minutes ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Only the passenger side is required. The driver's side doesn't do anything. I found it best to run at 15 psi on drag radials, and 20 psi on hard drag slick launches. On the street I would just let all the air out.
