Panhard bar?
Now, make note of which side is the smallest measurement - the axle will be biased to that side. Loosen the PHR jam nuts and twist the PHR body (its basicallt a big turnbuckle) to adjust its length. Retake measurements and compare. Continue this process until your difference is close to zero. Once you're happy with the result, tighten up your jamnuts (Loctite is a good idea), and you're good to go.
