Sway bar install, jacks or ramps?
on the bmr site there is a write up saying to use ramps... but can i use a jack and jack stands? i mean... i have those and i dont have ramps? does it matter if the suspension is loaded? if so, can i jack up the car, set it on stands, and then jack up the diffy? thanks
i used jack stands and then jacked up the diffy... i dont have a qorking torque wrench though, should i be worried about driving it? i tried to tighten it as much as possible... i think i got them all on ther pretty tight
You do want to tighten the bushings down, but the end links should absolutely NOT be tightened down. I don't remember the actual torque specs (mostly because I don't have a torque wrench myself), but essentially you only want to tighten the endlinks down right to the point where they are just starting to compress the bushings, and no more than that. This is another thing that can be tough to do on an unloaded suspension, but if you tighten them down any more than that, you're end link bushings are going to break apart in short order.
