Please Help with Koni set up
I have a 99 WS6 Formula M6.
I will be doing Solo2, Drag Racing and Street Duty.
The car will have :
-415 ci LS2 (approx 500 rwhp)
-Suspension Tech 35mm front Stabilizer
-Stock Rear Stabilizer with urethane bushings
-stock springs
-Spohn LCA Rod End
-Spohn PHR adjustable Rod End
-Spohn LT Torque arm
-Spohn Sub frame Connectors
-Koni DA front Shocks
-Koni 4th gen SA rear Shocks
-Moser 12 bolt HD posi 3:73
What would be a good starting point be for the Koni's for Street/Solo2/Drags
Tire will be Kuhmo V710 275/45-17 - Solo2
Michelin PS1 275/40-17 & 315/35-17 - Street
M/T 26/4.0-15 & 26/10.5 -15 - Drags
Any input will be appreciated.
Rampant
The car will have :
-stock springs
-Spohn LCA Rod End
Rampant
I put the rears soft for autox. The fronts are about 7 sweeps firm. I like the fronts at about 4-5 for street.
For drag racing I take the fronts to full soft, and forget to experiment with the rears...
(that's with Eibach front springs, stock rear springs, 35 hollow front bar, 21 solid rear bar)
