Torque arm owned
Look what Mr. Mickey Thompson DR did to me at 22 ponds of tire pressure and a 6000 rpm launch. Needless to say I need to work on my stock suspension some. What are you wheel standers out there running for suspension parts?
later,
Dave
FWIW, a Strange 12-bolt uses the 2 through bolt configuration, and I think the Moser 9" does too if I'm not mistaken.
I just slapped on those same MT DR's on Monday, and thinking of going to the track with a stock drive shaft and stock torque arm (M6, Spec 3, 413 rwhp)
Bad idea?
edit: I just noticed that the MT's were at 22 psi, and it still hooked that hard? Good God
I'm sure loose bolts could cause a serious issue but I wouldn't think you could blame this on the moser design. Just me .02 cents though.
FWIW, BMR rewrote their warranty clause on their torque arms to specifically void the warranty if used with a Moser 12-bolt or any other non-stock style (2 through-bolt) mounting design.
