SLP vs. Kenny Brown Sub Frames
KBDD's
You will not be able to paint the top on the SFC if you weld them on first. Just give them a couple of good coats of paint. You can wire brush the spots that need to be clean for the weld. Then touch them up after all is said and done. The car needs to have the suspension loaded when the SFC's are welded on. What I mean is to have it on a lift where the car is supported on its wheels just like it is going down the road. A lift where the car is lifted by the body with the wheels unloaded will not work.
Description of the SLP subframes. "The frames are constructed of 2" X 2", 1" X 1" and 2" X 3" 14 gauge steel tube and 1/4" steel plate."
So these have 2 inch steel tubes for the main part also, but the KBDD only have 1 inch?
No, the main length of SFCs is 2x3" tubing. Angled portion is 2x2. The three lengths of tubing that tie into the tunnel brace are 1x1". I removed the KBDDs on my '01 and replaced them with SLPs.
The SLPs are superior when it comes to bending strength, and I could feel that in the seat of the pants as well (big difference). What surprised me is the SLPs didn't appear to improve the torsional rigidity compared to the KBDDs, they were pretty much equivalent.
Can you actually tell a difference in the way the car rides and sounds after installing the SLP subframes? Will it make it louder in any way, i.e. clunking noises from dips in the road?
I read in another post that the BMR tubular subframes make the car feel just as rigid as the SLP double diamonds. I can't really see that happening considering they only run from the front to the back but who knows. I know that Rob Raynor ran the BMR tubulars and swore by them. His frame was straight as an arror pulling wheels in first and second running in the nines!
A friends of mine had a ten point cage welded in his car and he said he couldn't really tell a difference. I don't think he was really looking for it though. He has all stock susp. except for BMR boxed LCA's.
Also, I was looking into getting a Hotchkis STB. Can you tell any kind of difference with those.
