Unusual tire wear problem *PICS*
A few months ago the outside of my left front tire starting wearing pretty heavily. So before it got too bad, I took it to get aligned. The before specs on that wheel were (camber: -0.5, toe: -1/16) and after they were 0's on both.
Well that tire still was wearing bad so I put newer tires on the front to see if these would develop the same pattern. Well about 3000 miles later they're almost just as bad as the originals. The tire pressure was at 34 on the left and 33 on the right so this wouldn't explain it. I haven't wrecked it recently or anything so I'm out of ideas on why this is happening on only one side.
Only thing I can think of to fix it would to max out the camber on the 2 fronts. Any ideas what could be causing this and what could solve it?
![](http://img.photobucket.com/albums/v84/test1/tirewear2.jpg)
![](http://img.photobucket.com/albums/v84/test1/tirewear1.jpg)
too slow 02 whats your toe set at? also caster does effect tire wear only when turning. really high caster will wear the outer edges fast. helps cornering though.
i set my car at -.10 camber and 5.6 caster left and -.35 camber and 6.05 caster right, and toes +.05 each. tires wear great and its hadles great too corners nicely with almost no push. getting these was hard since i lowered it but it drives strait still. i set it up for a little road crown cause i drive intersates alot.
camaros come with alot of caster and camber, both wear the edges bad.
what were the settings before the alignment?? toe in (positive toe IE +.20) wears the outer edges too.
What about a funky Thrust angle? I recently had a 4 wheel alignment and can't understand why the -.2* thrust. What is acceptable? I thought you always started by zeroing this measurement. Here's entire report. Would really appreciate some coaching!
